Текстильная куртка Belstaff Trekker размер S
Demeo
Trekker Jacket
Mens three layer, waterproof and windproof jacket. The outer layer is hi-tenacity nylon with a Teflon, anti-stain coating. The waterproof breathable middle layer is a fully taped dropliner called "X-Hale". The inside layer is a Belstaff Laurel embossed lining made from 190T nylon.
Features:
* Waterproof, breathable and windproof
* Reinforcement panels on shoulder, elbows and back
* Reflective 3M braid
* Sleeve zippers are used to secure armor to the elbow
* Adjustable straps at the back neck
* Comfort fit waist belt with Velcro
* Elastic shock cord
* Six front pockets, four securely zipped with two side-entry hand warmer pockets
* Two way front opening zipper
* Fully detachable, zip off, back pocket bag
* Internal lining has water resistant rain skirt with non-slip elastic
* Lining has one large secure zippered pocket
* Full sleeve detachable quilted liner zips out
* Detachable lining has one large secure zippered pocket
* Ventilation zipper in front and back
* Zipper pulls with reflective Belstaff Laurel logo
Waterproof, windproof, breathable jacket in a 3 layer construction. The top layer is a high tenacity nylon shell with a Teflon® anti-stain coating with a light anti-fray PU undercoating. The middle layer is a fully taped X-Hale® dropliner which is waterproof and breathable. The inner layer is a Belstaff Laurel embossed 190T nylon.
* SHELL: high tenacity nylon shell with a Teflon® anti-stain coating with a light anti-fray PU undercoating. Reinforcement panels over shoulders, elbows, and back.
* WEATHERPROOFING 100% waterproof, windproof, and breatheable X-Hale® drop liner. Triple storm flap over front zipper. Velcro tabs at wrist allow easy entry and secure protection against weather.
* VENTILATION Ventilation vents on front and back of jacket can be opened or closed with easy to use zippers.
* INSULATION: Full sleeve detachable Thermolite® quilter liner (shown) with a zippered pocket and overlapped closure to prevent air leaks through zipper.
* STORAGE: 6 pockets - 4 zip / 2 handwarmer. Large pocket on back of jacket for max storage is removable.
Куртка АФИГЕННАЯ,таких уже не делают!Сделано в Великобритании.Но на меня маленькая немного...Рост 172 см,вес 62 кг
Думаю на худого парня или на стройную девочку пойдет!
Скоро придет защита плечей и локтей в неё,отдам в нагрузку,есть карман для защиты спины.Отдам за 200 бачей!
  • 3 недели спустя...
