Demeo Опубликовано 27 ноября, 2008 ; Поделиться Опубликовано 27 ноября, 2008 Trekker Jacket Mens three layer, waterproof and windproof jacket. The outer layer is hi-tenacity nylon with a Teflon, anti-stain coating. The waterproof breathable middle layer is a fully taped dropliner called "X-Hale". The inside layer is a Belstaff Laurel embossed lining made from 190T nylon. Features: * Waterproof, breathable and windproof * Reinforcement panels on shoulder, elbows and back * Reflective 3M braid * Sleeve zippers are used to secure armor to the elbow * Adjustable straps at the back neck * Comfort fit waist belt with Velcro * Elastic shock cord * Six front pockets, four securely zipped with two side-entry hand warmer pockets * Two way front opening zipper * Fully detachable, zip off, back pocket bag * Internal lining has water resistant rain skirt with non-slip elastic * Lining has one large secure zippered pocket * Full sleeve detachable quilted liner zips out * Detachable lining has one large secure zippered pocket * Ventilation zipper in front and back * Zipper pulls with reflective Belstaff Laurel logo Waterproof, windproof, breathable jacket in a 3 layer construction. The top layer is a high tenacity nylon shell with a Teflon® anti-stain coating with a light anti-fray PU undercoating. The middle layer is a fully taped X-Hale® dropliner which is waterproof and breathable. The inner layer is a Belstaff Laurel embossed 190T nylon. * SHELL: high tenacity nylon shell with a Teflon® anti-stain coating with a light anti-fray PU undercoating. Reinforcement panels over shoulders, elbows, and back. * WEATHERPROOFING 100% waterproof, windproof, and breatheable X-Hale® drop liner. Triple storm flap over front zipper. Velcro tabs at wrist allow easy entry and secure protection against weather. * VENTILATION Ventilation vents on front and back of jacket can be opened or closed with easy to use zippers. * INSULATION: Full sleeve detachable Thermolite® quilter liner (shown) with a zippered pocket and overlapped closure to prevent air leaks through zipper. * STORAGE: 6 pockets - 4 zip / 2 handwarmer. Large pocket on back of jacket for max storage is removable. Куртка АФИГЕННАЯ,таких уже не делают!Сделано в Великобритании.Но на меня маленькая немного...Рост 172 см,вес 62 кг Думаю на худого парня или на стройную девочку пойдет! Скоро придет защита плечей и локтей в неё,отдам в нагрузку,есть карман для защиты спины.Отдам за 200 бачей! Ссылка на комментарий Поделиться на другие сайты Поделиться
Demeo Опубликовано 28 ноября, 2008 ; Автор Поделиться Опубликовано 28 ноября, 2008 ТОРГ Ссылка на комментарий Поделиться на другие сайты Поделиться
Demeo Опубликовано 29 ноября, 2008 ; Автор Поделиться Опубликовано 29 ноября, 2008 уже есть защита спины,локтей и плечей KNOX,ОТДАЮ В НАГРУЗКУ такая стоит отдельно 70 бачей Ссылка на комментарий Поделиться на другие сайты Поделиться
Demeo Опубликовано 3 декабря, 2008 ; Автор Поделиться Опубликовано 3 декабря, 2008 5000 рублей Ссылка на комментарий Поделиться на другие сайты Поделиться
Demeo Опубликовано 18 декабря, 2008 ; Автор Поделиться Опубликовано 18 декабря, 2008 Народ забираем куртяк ... Ссылка на комментарий Поделиться на другие сайты Поделиться
tato Опубликовано 19 декабря, 2008 ; Поделиться Опубликовано 19 декабря, 2008 живешь далековато видимо, и размер никому не подходит Ссылка на комментарий Поделиться на другие сайты Поделиться
Demeo Опубликовано 19 декабря, 2008 ; Автор Поделиться Опубликовано 19 декабря, 2008 tato, я в курсе но я не теряю надежды) Ссылка на комментарий Поделиться на другие сайты Поделиться
Demeo Опубликовано 19 декабря, 2008 ; Автор Поделиться Опубликовано 19 декабря, 2008 Размер реально я думаю ближе к xs Ссылка на комментарий Поделиться на другие сайты Поделиться
Mentos Опубликовано 20 декабря, 2008 ; Поделиться Опубликовано 20 декабря, 2008 А на русский размер это скока? Ссылка на комментарий Поделиться на другие сайты Поделиться
tato Опубликовано 20 декабря, 2008 ; Поделиться Опубликовано 20 декабря, 2008 46-48й примерно Ссылка на комментарий Поделиться на другие сайты Поделиться
